I remember reading here about drilling in thin material with a standard drill bit, the hole is 3 sided so to speak. And it happens. So how to drill a round hole? I simply have some plastic gas can vents, to make those blasted new cans more usable. The maker says to drill a 31/64 hole and push in this vent. I have both plastic and metal cans I want to drill, and I would bet they won't drill round. I have the drill bit but not a chucking reamer that size. Ideas?
Drilling a ROUND Hole
For perfectly round holes in thin metal get hold of an old adjustable reamer and reverse all of the blades so that they'll cut a taper. Drill a pilot the size of the small end then open up the hole with the reamer in a battery drill to your required diameter. Perfect round and burr-free holes.Peter - novice home machinist, modern motorcycle enthusiast.
Monarch 10EE 1942
- Likes 2
Holesaw.
Or use the rag trick.
I didn't have any problems drilling the holes for the vents in the plastic cans. And the holes came out round. For the metal cans, put a block of wood over where you want the hole and drill thru the block and the metal at the same time. The resulting hole should be good enough for the vents.
Originally posted by rws View PostI remember reading here about drilling in thin material with a standard drill bit, the hole is 3 sided so to speak. And it happens. So how to drill a round hole? I simply have some plastic gas can vents, to make those blasted new cans more usable. The maker says to drill a 31/64 hole and push in this vent. I have both plastic and metal cans I want to drill, and I would bet they won't drill round. I have the drill bit but not a chucking reamer that size. Ideas?
Hal
- Likes 1
The guide block is the best way for thin flat material. I have a couple of boxes of sheet metal drills, for drilling for 1/8" rivets, they are stub form and the sides do not have any relief like ordinary twist drills. The cylindrical outside reduces the lobing that ordinary drills can produce.
Originally posted by old mart View PostThe guide block is the best way for thin flat material. I have a couple of boxes of sheet metal drills, for drilling for 1/8" rivets, they are stub form and the sides do not have any relief like ordinary twist drills. The cylindrical outside reduces the lobing that ordinary drills can produce.
JL..............
