I've been using Lenox Bimetal blades for a long time, and finally snagged a few teeth out of my last 18 tooth one. Went on line looking for a good price on some new ones, and was amazed by the plethora of brands available. I guess it's been quite a while since I had to buy blades. Now I have to wonder if I should be looking at some other brand. What say you? Do you have a favorite?
Best hacksaw blade
I have not used a Sandvik, but I have used all the others mentioned. I used a Starrett today, just a few minutes ago actually. I think the 'trick' these days is making sure you use a genuine blade by any of these makers, and not a fake copy.
I have used a Sandvik file- that's been the best file I've ever had.I seldom do anything within the scope of logical reason and calculated cost/benefit, etc- I'm following my passion-
I've used Lennox blades for years, mainly because that's what the local industrial hardware store carries. But they have always been a good quality blade. I have three hacksaws in my shop each one has a different type blade on it. I grabbed the one I need when I need it.
I've snagged a few teeth broke a few here and there. When the blades get dull I just replace them they're not that expensive.
JL.....
Locally along with the usual cheaper mystery brands I've got Starrett, Irwin and Lennox as options which at various times I've bought and used. At present between the two spots where I use hacksaws I've got four saws so I don't have to switch from coarse to fine. I've got 2 Lennox, 1 Irwin and a Starrett in use currently.
The Starrett blade is my first and it's too early to say how it compares well to Lennox. The Irwin blades are a far cry from the Lennox but still far better than the "no name" stuff. If Irwin is the only thing you can find on the rack beside the no name option I'd go with it. But if a 10 minute extra drive will get you to where you can buy Lennox I'd say it's time and gas well spent.
Chilliwack BC, Canada
Lowes sells Lenox, but they are quite a ways from my home. Fortunately, I have to make a trip today that will take me right by one of their stores. I'll pick up the 6 piece set that sells for $9.98. 2 each 18,24, and 32 tpi. Perfect for 3 saws.“I know lots of people who are educated far beyond their intelligence”
Lewis Grizzard
Originally posted by Mcgyver View Postcan't say I've noticed much of difference from one blade to another, but I picked one of the high tension frames recently....that makes a differenceCNC machines only go through the motions.
Originally posted by Dave C View PostI've been using Lenox Bimetal blades for a long time, and finally snagged a few teeth out of my last 18 tooth one. Went on line looking for a good price on some new ones, and was amazed by the plethora of brands available. I guess it's been quite a while since I had to buy blades. Now I have to wonder if I should be looking at some other brand. What say you? Do you have a favorite?
These are 24tpi. I also have used the Lennox blades at work so and they are top notch. JR
