Well, if you've been keeping track on the number of semi-OT posts I've made lately, you might start to see a pattern! I'll be putting my house on the market in the next year and moving my shop, so I've been thinking about what I need to get done around the property to sell it and what I need to move my shop efficiently. Hence the posts on backhoes, trailer tires, and the like.
Anyway, my trailer is about 12 years old or so and it has a pressure treated wood deck. No signs of rot, despite the fact that I keep it outside. However, the sunlight is starting to take a toll on the wood. The exposed surface is starting to dry, check, and splinter. I was thinking about some kind of opaque deck paint - not so much for waterproofing but more for UV resistance. Obviously it needs to be reasonable tough to stand up to use and abuse. But I don't want anything too thick that will fill in the screw heads for the decking. When it comes time to replace boards, the last thing I want to fight is chipping globs of paint out of the Torx heads so I can get a bit in there. The other complicating factor is that the wood deck does have some oil stains on it from one of my milling machines. I forgot to empty the sump before moving it
Any recommendations?
I know used motor oil / diesel is a common protective coating but not what I'm looking for here.
