I use one similar to right hand one in wooden block, but has 3 setscrews. I took a 1/2 shrank brazed carbide, thinned 1/2 'of the shank so it would fit the slot and catch 2 set screws. Then I ground a round profile on the tip , a small chipbreaker giving a bit if positive rake.
now keep in kind fly cutter. NoT a face mill .. light cuts , low removal.. flatten things.
so it cuts a 6 inch swath on a B,port type mill on regular steel or aluminum.... does a nice job...
so much for too much stickout.........light cuts, use positive rake for easier cutting, less beating up of machine..
I also have shorter tools for it. And I also use my boring head, sticking out the side hole ... probably 8 inch swath..
