Originally posted by 754
View Post
First time fly cutting
Originally posted by challenger View Post.............I'm feeding so it cuts below the rust as I've read about. Are there any obvious setup issues I'm in error doing? The chips are a huge issue as well and I'm going to make some sort of cardboard containment as they are getting thrown all over.
Thanks for any input. ..........
My choice in this would probably have ended up with "use a flap wheel on the rust, grind down the weld, and see how flat it is.... (the dang thing is a griddle!". I do not recall being upset about how flat my hotcakes are.........)
After the weld is ground down, and the rust removed, the edges probably do need to be flat enough to sit on the supports, but that is not hard to deal with.3751 6193 2700 3517
Originally posted by john b View PostRedlee , I am talking a out brazed carbide ir highspeed steel. Different hights and diameter. The smaller dia should stick out a few thousand more.
I can rough it with a single cutter fly, then put a finisher in and take a finishing cut faster than it takes to set a 2 cutter fly up.
Each to his own.Beaver County Alberta Canada
Looking at this again, I do not know that you needed to fly cut it, and probably did not really need to "get below the rust".
I reground a tool bit and I'm making good progress fly cutting. I'm only taking about 20 thou per pass. This is time consuming but at least I'm learning something. Like fly cutting 15" square plate sucks.
- 1 like
Originally posted by 754 View PostWhat ? Seriously? You cant touch cutter to work, lock spindle, slide second cutter to touch work, and lock in place , in like 3 or 4 minutes..or less.
well then , maybe we really cannot help..
When we did line boring with shop made bars it was a pain to move the tool a few thou.
Thats why insert cutter heads have been around forever and are repeatably accurate.
As stated before each to his own and what works for you is what you do. I dont see the sense in continuing this debate, I do it my way and it works ,you do it your way and it works.
So on with our days and have a good one.Beaver County Alberta Canada
I ended putting the plate in my spooge tank. It took all the rust off perfectly.
The cutting tool geometry might not be doing you any favors either. I know from my shaper work that the finish was horrid until I stopped using my "that looks about right" lathe tools and ground up some new tool bits with shapes and angles found in the shaper books I've got. Perhaps play with the tool bit geometries with your new flycutters.
I was looking at videos on shaper cutters and one in particular took a minute to explain that the top and back rake on the cutter was needed to ensure that the chip was not pushed back down and into the cut. The shape on a typical brazed carbide lathe tool usually has a little back rake but no end rake. Plus the impact against the harder weld beads might be micro chipping your carbide which leads to a nasty finish. You might be better off with HSS that is ground with a bit of both side and back rake.
And yes. due to the need to feed very slowly by virtue of the low RPM and the need to extend fully off the end of each pass by the full diameter of the sweep flycutting is notoriously and frustratingly slow. One reason why my shaper is becoming my go to machine for turning hot rolled surfaces into nice clean surfaces before progressing onto the rest of the projects. Especially now that I've smartened up and started proper shaper tool geometry.
Chilliwack BC, Canada
One thing that makes a good flycutter is flywheel (mass).
You have no doubt heard spline chatter in the mill when flycutting.
Adding some friction to the spindle while wearing a leather glove helps some.
But having a very heavy flycutter (mass) helps carry the cutting bits through the cut.
Some larger mills, like Kearney and Trecker have flywheels inside their body, on the spindle shaft.
My Groton mill has a spindle spline lash eliminator adjustment also.
Again, nice fly cutter, might have even been smoother performing if the sides were not trimmed off
and the full round was left to add mass. But it is nice and beefy just as is.
--Doozer
DZER
A very nice cutter indeed.
--Doozer
3/4" straight shank, 2" 3 insert face mill $46 http://www.cdcotools.com/
I parked the fly cutters a few years ago as I got a 2 1/2" 4 positive rake insert wuhanium face mill on an R8 shank for like 35 bucks on ebay from a usa vendor. I bought a couple boxes of spare inserts and after using the thing perhaps 50 times it's still on the original inserts edge that can be flipped around. I can't even think how many times I had to regrind tools for the fly cutter as I got a bit aggressive on the rpm or feed rates and burned the edge off. Or the tool slipped a bit and suddenly is taking less of a cut.
Having used this modern contrivance, I maintain why bother with the chatter and the possibility that a fly cutter will 'fly' out of the holder. These shell jobbies are robust and you can spin the hell out of them as opposed to low rpm and a few thou per revolution creep along feed rates of a fly cutter. I say pony up the $50-70 bucks and you'll have something that works well for life.
