Best use for this motor?
  • #16
    Originally posted by mickeyf View Post
    So what happens with a 3 phase motor when it is "instantly" reversed? (I can imagine the magnetic fields needing a visit to the chiropractor...)
    The motor loses quite a bit of the energy as heat during the reverse. That's where all of it ends up eventually.
    • #17
      Squirrel launching videos? Is that the ones where someone is trying to keep the squirrels away from the bird feeder? They can be very entertaining. If I gave in, it would be at least two hours.
      Originally posted by I make chips View Post
      Oh no,, Matt is gonna get me watching squirrel launcher videos again. There goes an hour.
      • #18
        In either case, thermodynamics rules. That energy becomes heat.
        And you have contributed, in some small measure, to the heat death of the universe. It's all downhill until everything is at the same temperature.
        Not quite instant - but less than a second. And yes, all that energy must go somewhere....
        I used a center off 2PDT switch. So power to the motor is cut off more or less at the same time as the power to the brake. It must take some number of milliseconds for the brake, powered by mechanical springs, to actually bring the motor to a halt, and some further amount of time for the motor and brake to be re-energized the opposite way when the other set of switch contacts connect.
        • #19
          Bomb Bay doors on a 1/4 scale RC model of Enola Gay.
          • #20
            Doozer: Motors with a run capacitor generally are a lot smoother than regular split phase and plain capacitor start motors (the latter may have a run cap).
            • #21
              Interesting. Did not realize that.
              Possibly why Baldor uses capacitor run motors
              on their single phase bench grinders.
              -D
              DZER
