how to repair auto down feed.......will not stay engaged.....Bridgeport Clone
Bridgeport Clone
there a simple mechanize down load a parts brake down try to adjust it first check the little pivot at the bottom they brake if it wont work after that it's most likely the the little dog bone at the top is broken the front haft is easy to get out back half sometimes sometimes comes out with a magnet or air if not make a drill guide and tap 6 or 8-32 will work.The guide needs to bottom on the ball half still in the head only need to drill deep enough 1/8" or so to get a few threads in the ball to pull it out. after you get it drilled and tapped lave the tap in the ball remove the guide and pull the and pull the broken bone half out with the tap.ken
- 1 like
That happens to my BP clone every now and then.
Mine is just like a BP, I know this because a BP sits about 10' away from my clone and I can match things up.
The 1st time it happened I tore things apart, only to find it was gummed up with WD 40 residue.
I cleaned it up and it worked fine. The couple of times it's failed my since I just soak it down with PB Blaster and away I go.
The WD 40 comes from my using it as lube when cutting alum.
THANX RICHPeople say I'm getting crankier as I get older. That's not it. I just find I enjoy annoying people a lot more now. Especially younger people!!!
Originally posted by ken View Postthere a simple mechanize down load a parts brake down try to adjust it first check the little pivot at the bottom they brake if it wont work after that it's most likely the the little dog bone at the top is broken the front haft is easy to get out back half sometimes sometimes comes out with a magnet or air if not make a drill guide and tap 6 or 8-32 will work.The guide needs to bottom on the ball half still in the head only need to drill deep enough 1/8" or so to get a few threads in the ball to pull it out. after you get it drilled and tapped lave the tap in the ball remove the guide and pull the and pull the broken bone half out with the tap.ken
