Originally posted by JoeLee
View Post
As for doing this at home with home solutions first off you need some way to create a topographic mapping of the table. It would be nice if you could set up two long straights on opposite edges that are dead nutz parallel and then some sort of bridge that you can measure from. But whatever you have and are comfortable using. It could even be your planer blade and a back light used to locally check for dips and peaks.
Obviously we don't need "surface plate flatness" here. We're only after the idea of reducing the mountain to a series of insignificant hills. And I'm sure you've got an angle grinder for doing the bulk of the really way out of spec work and reduce that portion of the bull work.
For flattening out after the power work and working down an area to final flatness I'd suggest a large flat file (check for being straight first) held in a simple wood holder that grips the edges and "hand plane" the area to flatten out the local crests. and reduce the "foothills" to blend with the flat areas around the rest of the table.
I know this sounds like a heap of work but I suspect that provided you can figure out a way to easily find and check the humps and valleys that you can remove them with only a few hours of work. It won't be "surface plate flat" by any means. But as the others are quick to point out "it's just a table saw". But with not too much work I feel like you or I could flatten the top to a degree that by wood working standards it would then be better by a lot than simply "good enough".
Before all this work though I'd still want to flip the table over and ensure that the trunnion assembly isn't simply pulling the table out of spec. And to check the fit of the top to the lower base It would be.... a little frustrating?... to find that the trunnion assembly or the base is out of whack and is pulling up a wave in the table. It's a good time to check and correct any misalignment of the trunnion assembly to the table slots anyway while you're at it.
