Wood Screw or Machine Screw?
Originally posted by MrWhoopee View PostThe ones I've seen came with door hinges. No clue why.*** I always wanted a welding stinger that looked like the north end of a south bound chicken. Often my welds look like somebody pointed the wrong end of a chicken at the joint and squeezed until something came out. Might as well look the part.
- Likes 1
Originally posted by MrWhoopee View PostThe ones I've seen came with door hinges. No clue why.CNC machines only go through the motions
- Likes 1
Originally posted by JoeLee View PostI've seen double threaded studs half wood screw thread half machine thread.
JL..............
Edit: They're called hanger bolts
If you don't mind, it don't matter.
I used those to secure the fenders to the frame on my '51 Riley DHC. I used to know what they're called.
Hangar bolts ...I think. Or maybe it's hanger, not hangar.Lynn (Huntsville, AL)
Already been said, but those are the screws that generally come with door hardware like strike plates. I believe the theory is that they work in both wood and metal frames. For wood, the threads at the tip provide the holding power, for metal the fine thread is the part that grabs and the wood thread extends through the frame and into the air. My understanding of it at least
That said, worth avoiding using the supplies hardware when possible. Easy way to improve home security is to replace the screws in door hinges and strike plates with much longer screws that reach all the way into the studs. Pretty easy to kick a door in that just has the factory screws holding the strikeplate, much harder when the plate is secured to the stud
I can see how they work for wood. But for metal the wood screw thread has to pass through the sheet(?) metal frame first and then the machine screw thread. So the metal frame has been distorted by the wood thread before the machine screw thread does. There is a lot going on there. I don't think this is a good idea.Paul A.
