rattleback
  • rattleback
    my rattleback turns clockwise. i see them turn anti-clockwise on youtube. would it turn the other way in australia? what has to be done to get it to turn the other way? make a mirror image about an axis, about the center?
    Translation please...haven't got a clue what you're talking about...
    Keith
    __________________________
      My dickfor swings too low and my henweigh is killing me.
      -Doozer
      DZER
        Here in PA my rattleback goes all kattywhampus
          https://www.youtube.com/watch?v=11NHjiEYnI0
            I read somewhere that the earth has loads of N and S poles all over, they apparently move about, relavent?
            Mark
              The Knifter pin is loose in my knute bearing, and I'm on the last oversize. What to do?
              Oregon, USA
                Wrong knifter pin, you used the left clockwise interrupted sputum metric one I think
                m
                  Christ,, and I thought I was bored.
                    You have a cheap rattleback. Most (like yours) only reverse when spun in one direction. Some don't like being spun in either direction, and whichever way you spin them, they'll reverse.
                    I think these are normally carved out of unicorn horn.
                    Ian
                    All of the gear, no idea...
                      Two other things that operate in reverse south of the equator. When you pull the plug out of the bath-tub, the whirlpool above the drain revolves opposite south of the equator. When a dog turns around 2 or 3 times before laying down, they turn the opposite direction south of the equator.
                      Design engineer
                      Barrie, Ontario, Canada
                        are the rattlebacks in oz self contained with a hi-speed self oiling chingaso ?
                          m
                          Well that must mean that I'm opposite left side dyslexic.
                          Oregon, USA
                            The water in toilets in the northern hemisphere circles counter-clockwise, whereas those below the equator exhibit the opposite behavior, due to the Coriolis Effect. Toilets close to the equator don't flush at all, which is why so many countries in that region are called "turd world nations"...
                            USA Maryland 21030
                              Jeezus...it just keeps getitng worse...😄
                              Keith
