I did not feel like making anything this morning but in view of the problems Brian seemed to be having with his 3 jaw I made a few tests on my 60 yr old Southbend 9 inch lathe and the accessories I use.
The dial gauges I usually use are marked in thous, For the tests I used ones marked in half thous.
Mandrel register- od - no perceptible movement of needle, Bore of spindle again no perceptible movement. Face chucks screw against again no perceptible movement.
3 jaw chuck surprisingly good,using marked keyhole 0.0005 inch tir measuring at chuck face, at 2 inches out the same.
Using other keyholes0.003 inch and 0.0025 tir at face, at 2 inches out 0.005 tir both.
4 jaw I got the face to 0 -0 ie no perceptible movement of needle. at 2 inches out 0.002 Tir.
3 C collet, running on adapter in mandrel nose at face ran at less than half a division movement, probably less than 0.0003 inch at 2 inches out 0.001 Tir.
5 C collet running in screw on collet chuck, at face ran at 0.0005 Tir, at 2 inches out 0.002 Tir.
All tests were done using a seven sixteenth dowel pin. Mandrel was turned by pulling on the primary belt.
My collets are all secondhand, the 3 C s are in literally mint condition, whole set to half inch cost me 300$. The 5 Cs are old and they and their chuck have quite a history, from England to South Africa to Canada.
I hope this is of interest and perhaps help to someone.
Regards David Powell.
