This lathe has had a somewhat unsuccessful CNC conversion done in the past and now I want to convert it back to manual operation. Parts have been lost. While many can be made or bought locally some gears are problematic. The power feed worm and worm wheel and the cross feed power feed drive pinion are missing.
have figured out the cross feed drive pinion is a module 2 22tooth 10mm thick gear. It is a little more difficult to figure the specs for the worm pair. The axial spacing is ~28mm, the worm tooth spacing is ~5mm, the wheel has 17 teeth and the pitch circles look about equal from a photograph.
If anyone can provide accurate specs and better still a source, for these gears it will be much appreciated.
Thanks, John.
Error in title, can't correct: BusyBee GF127G should read BusyBee GF1237G
Thanks, John.
