At some point, I will post a thread about some work I've been doing to one of my Bridgeports but one of the tips I was going to share is for just this kind of situation.
Instead of trying to TIG weld an extension onto the pin, put an 1/8" collet in the TIG torch and clamp onto a piece of 1/8" filler rod. No worries about spatter with the cast iron and all you have to do is get a small arc started and then dip the filler into the puddle while letting off the trigger. You just fuse the two together similar to a stud welder. Then remove the torch and pull on the filler rod with slide hammer, etc. to remove the stuck bit. Very little heat involved but probably just enough to loosen any Loctite. Works really well for pins that are broke off below the surface and / or are too small to TIG a stub to in the ordinary way.
Assumes you have access to a TIG welder, of course.
