Metal nut cracker plans
  • #16
    The black nylon one, I made similar long ago . Took a 1 3/4 nut bored threads out, then tapped the side.. works good...
    get it.., NUTcracker....
    • #17
      The second of the initial three looks best because of the presentation, including some wood. I think it would be nice and extra fun to have a sort of ship's wheel to adjust teh screw in bit. For a machinist that could be a standard machine handle, with a dial for thous of adjustment. The real test is how well they cope with brazil nuts although almonds can be pretty tough sometimes.
      When the aim is just to get the nut cracked the best by far is a pair of vice grip pliers, we call them 'mole grips' over here.
      • #18
        Originally posted by lugnut View Post
        OK. I think I figured out why my photo did not show. any way here is the photo of my old nut cracker that was in the things that I got when my Dad past. I really like because of the control you have when cracking a nut. I think it was chromed at one time. It's stained, pitted but still works great. I have thought about making one like it, but not sure how to go about it.
        That's the same one I was talking about!
        • #19
          Originally posted by flathead4 View Post
          I don't see your picture either.
          I can't see lugnut's original photo either but I can see his photo in post #14.
          • #20
            A screw cracker is fine if you're only going to crack a few nuts on which to snack. However, it can be tiresome if trying to crack a bunch of nuts for pies or cookies. The lever type is much faster for production quantities.
            A chisel edge in contact with one side of the nut will help to crack Brazil nuts and macadamias.
            Regards, Marv
            • #21
              thanks for the pointers everyone. Finally got everything else done on my bench (for now at least) and rounded up some stainless from my collection.
              the big piece in the middle can be split in two lengthways to make the top and bottom halves, the plate can be used for the legs and linkage and the rods for axles and the lever. I have some larger bits of stainless (including one I call Thor's Hammer!) that I can make a handle out of to make it a bit more comfortable to use. Pretty sure I have a piece of red oak around that would make a nice stand.
              First thing will be to make some measurements off that picture to get the various lengths, then rustle up some nuts (oh er) to figure scale. Then I'll make a cardboard model to see if the dimensions make sense. After that, I'll need to make a pointy die thing to bend the legs and start cutting. The axle that connects the lever to the plate on the other side will be square ended, so that the lever will drive both sides at the same time.
              I'll update as I go, the clock is ticking!
              • #22
                also, weird thing with the two pieces of 304 at the bottom. Totally non-magnetic in the middle, but both have shiny tracks at the edges which are magnetic. What's that all about?
                • #23
                  I just made one today because of you!
                  I found a large nut in my shop that measured 1 13/16 inches across the flats so decided to make a novelty gift for a friend.
                  • #24
                    nice!
                    Did some CAD (cardboard aided design) this evening after eyeballing the measurements off the picture.
                    First attempt, not so good
                    2nd and 3rd attempts weren't so great either
                    Final version
                    I'll have to think carefully about clearance for the lever over the upper linkage nut. Might also extend the top and bottom pieces by a cm. Think I'll do some doodles and work through some ideas on paper. Have to be careful with the clearance stack up between the links too, especially if I'm using shouldered bushings.
                    Full open the range goes from ~12mm or so (hazelnut), flat to flat, at the hinge end to ~45mm half way along (big walnut), so that should work.
                    • #25
                      I have one similar to this, but mine has a double thread on it. Probably from the 1890s. Made in England. Works like a champ! I am sure yours, like mine was nickel plated.
                      • #26
                        Cool ..i just remembered I have about 6 feet of 2 3/8 or so hex steel bar.. not sure if it saws easy.. but cheaper to buy a 1 3/4 nut I think and less drilling.
                        • #27
                          I'd think a miniature power hammer would be a cool nut cracker
                          • #28
                            Better yet, a complete steam powered bar set.
                            Stuart used to market a casting set for a steam hammer. Add a cement mixer...
                            https://www.homemadetools.net/forum/...4841#post64384
                            to mix drinks, all driven by a steam engine fueled by the espresso boiler.
                            A tiny horizontal bandsaw to slice citrus and an arbor press (PMResearch model) for pitting olives...
                            https://www.homemadetools.net/forum/...629#post104841
                            The possibilities are endless.
                            Regards, Marv
                            • #29
                              a steam powered power hammer nut cracker would be totally awesome (as would a trebuchet squirrel launcher, but that's another story) but the likelihood of getting it done before Christmas is exactly zero, maybe a little less
                              Turned my CAD model into paper drawings. There are going to be a surprising amount of parts in this. The ones that worry me the most are the legs that I'll have to bend in my hydraulic press (need to make a pointy die thing for that) - I think I've allowed the right amount of internal radius, but I'll be drilling the top holes after I'm done.
                              Got a few bits made, will take pictures once I've finished up for the evening.
                              • #30
                                How about a supersonic squirrel gun, like "Smarter Every Day" did on Youtube for baseballs? Oh wait, the squirrel wouldn't like being in a vacuum among other things...
