It is important to recognize there are two completely different grounding methods for completely different purposes. The goal of Power grounding is to have as many ground loops as possible. This is so that when a fault occurs where 5000 amps may flow no two pieces of adjacent metal will have a potential difference that could be dangerous.
The goal of Signal grounding is to keep noise out and that to work you want no ground loops at all that might allow current to flow. So a single ground point with a separate ground wire from every device and every shield is way you make this happen.
The two methods can be tied together but only at one point.
