Originally posted by The Artful Bodger
View Post
O/T: Computer Q. Moving files from one machine to another?
Originally posted by JRouche View Post
So why a new HD? Was almost comparable to the USB patch cord and will have drivers for my broke azzed computer, I hope
I couldnt justify 28 bucks for a USB patch cord that I may use once. HD will be good to have. Thanks.... JR
Good luck with the new HD. Keep in mind that you will be using the bad drive to run the PC. That means the computer will be reading and writing to the bad drive so the chance of failure is a bit higher than it would be if you were using the bad drive as a read-only slave to the new computer. If possible, look for a copy program that can restart where it left off when you crash. That will make it MUCH more tolerable. I don't do windows anymore, so I don't know which currently produced programs have that feature.
Dan
All great info. That is why I went all crasy O/T: haaha..
The (2) SATA to USB is in the mail. That was the seven dollar cable.
The USB to USB was 28 bucks. And software dongledNo tanks.
I am receiving my 300 dollar computer soon from dell. This box will be wiped and looked over. Not discarded.
This box is very old and does not belong on the internet. Heck, my Bridgeport computer is even older. Maybe swap? No, wrong answer. DOS box
Oh??? I accidentally lied. I do use one of the laptops I have. Happens to be one of the oldest also. She feeds the 120 Emco numbers. I forgot. JR
1.4 tb of data ? For an old computer, that's a pretty big HD. After 1 tb it pretty much jumps up by a whole tb, 1tb 2tb etc. Odds are the HD is fine.
I would do like someone else suggested and just take that HD out and put it in your new computer as the backup drive. It would take minutes and
your done.
Or .. you could just reinstall or upgrade Windows and the BSD would probably go away.John Titor, when are you.
Originally posted by Mike Amick View Post1.4 tb of data ? For an old computer, that's a pretty big HD. After 1 tb it pretty much jumps up by a whole tb, 1tb 2tb etc. Odds are the HD is fine.
your done.
I can talk FTP. I dont want to for this TV computer. Its just a swap. I thought the tech got better ovr the years. And it did.
Yu guys have helped me significantly. I thank you.. JR
Edit: Yes. I only need to remove 1.4TB at the max. It is a 2TB HD. No software coming. Just my files.... JRLast edited by JRouche; 11-29-2020, 12:43 AM.
