New Mag drill for the shop
Yep, magdrills are awesome, we have three at work, all big ones, including one ancient B&D with a lifting eye that needs it. I've had my eye on one of the Hougen HMD 130 ultra compact ones for awhile-
https://www.hougen.com/mag_drills/HM...mag-drill.htmlI just need one more tool,just one!
Originally posted by wierdscience View PostYep, magdrills are awesome, we have three at work, all big ones, including one ancient B&D with a lifting eye that needs it. I've had my eye on one of the Hougen HMD 130 ultra compact ones for awhile-
I have one.
Fabulous.
Just a note, the cutters have a twist-lock shank connection.
Some kind of automotive quick change standard or aircraft drill type standard.
I forget which. But you can not use the regular 3/4" Weldon shank cutters.
They are special from Hougen or possibly others, not sure.
-DoozerDZER
Mofo is 106lbs. Splits into 2 pieces thankfully, but it's still a grunt. Humorously, that's the most powerful (HP wise) drill press in the shop. Also the loudest, by a factor of probably 20. Also interesting is that the serial no is 80090001. Suspiciously even.
I'd really like like a 15lb version. For scenarios where it's awkward to use a hand drill, or you have too many holes to do, or need them very straight. I think Milwaukee has one that's like 22 lbs, but it's pricey.
Originally posted by The Metal Butcher View Post
One of these bad boys?
I saw one of these in action recently and liked the looks of it, some pretty unique features on it-
https://magswitch.com/product/magdrilldisruptor43/
is really designed to allow the head t swivel to one side or the other when reaching around obstructions.
Mine has the lifting eye on top but I usually move mine around with a hydraulic lifting table. Raise the table to the height
of the work, slide the drill on and have at it. Reverse the process when returning it to storage. I've only used mine on flat
surfaces so far but if you were ever drilling horizontal holes you'd definitely want to have a safety chain. At my age I think
I'll leave that to the youngsters.
I just recently finished a new welding table that required about 150 1/2" holes through a piece of 3/4" plate. Would not
have happened if I had to drill the holes by hand. (Coincidentally I do have an almost identical Black & Decker drill motor
that is virtually the same size--I know how much work it is to hand drill just a few holes so 150 would be out of the question.)
And yes, that sucker is loud--it has the most irritating high-pitched whine to it. Definitely requires ear protection...
Keith
__________________________
Very similar, ours is a bit older and doesn't come apart. Drill motor says 1-1/4" capacity and has a #3MT female drive adapter. The other two, one is a smallish Nitto-Kohki which is very nice and the dog of the group a Milwaukee. Not that the Milk is a bad machine, it's just heavy and Milk decided it would be a good idea to put all of the controls on one board that costs $500 when it smokes
Originally posted by LKeithR View Post
I have one identical to that as well. Two speed, gearhead, reversible. Can be taken apart if required but that feature
I've only seen the hand mt3 models in catalogs. Lord what a drill. 3 man operation IMO.
That low profile posted above could really come in handy in tight spots. The one in the video with the added spindle support down low by the magnet looks like a good feature but if it’s not removable I could see it being a problem in some situations.
We just got a new Milwaukee fuel cordless mag drill at work. It has pretty decent run time on the 9 amp hour battery and the magnet engage is mechanical not electric which is nice. I also like the quick change Weldon style chuck on it and we got a jacobs with Weldon shank to go with it. Only real complaint is it has a smaller throat depth compared to others I have used so it limits what size hole saws can be used. Reverse would also be nice for tapping with it.
Originally posted by swatkins View PostToday I broke out the Hougen HMD905SK mag drill for the first time... It worked great and I am kicking myself not not buying one 35 years ago! Made a nice ladder for the mezzanine with about 45 dollars of material... Please take a look
They are good tools to have when you need it.
Lil hint. There is a guy on ebay that is selling these Jancy bits for a good price, very good.
Had to cut some holes in my 1-1/2" welding table, ate like butta. JR
Edit: I enjoyed the vid also..
I have been wanting one for a long timeI have several project coming up that just cry for a mag drill, CNC router/plasma table is the main one I was thinking about. I have lots of holes to drill in the 10" c-channel that were going to be a chore on the drill press.. With this baby it will be a piece of cake.
