I need to broach an 1/8 inch keyway in a 7/8 bore. I have an 1/8 inch broach - acquired with a small lot of items at a grinder shop auction. Problem is that the broach is more than 7/8 inch wide. I know I could use my lathe carriage as a shaper - I have tried a couple of times in the past to use the carriage to shape with no success. I could buy a new import broach for about $40 (unless I was willing to wait a month or more, then I could buy it for half as much). So I am interested in removing stock from my existing broach. I tried a knowingly somewhat dull carbide endmill and got more rubbing than cutting. I presume the broach is HSS or similar. How could I mill it? If not milling, I could hack off the majority of the excess with zip discs and then would need to grind the hacked off surface smooth - I don't have a surface grinder. I could cover the mill knee ways and put a grinding wheel on an arbor in the mill - mill highest speed is about 5K rpm. Ruining the broach is of no concern - it owes me nothing and if I can't use it when needed, it is of no value. Other ideas?
Need to modify HSS? broach
I suggest you buy a standard push broach. What you have pictured is a specialty broach, ie no taper in the body, only in the cutting teeth. My 1/8" standard push broach body measures roughly 3/8" at the small end and 1/2" at the large end. Make it easy on yourself and get a standard broach and bushing.
👍 2
Originally posted by nc5a View PostI suggest you buy a standard push broach. What you have pictured is a specialty broach, ie no taper in the body, only in the cutting teeth. My 1/8" standard push broach body measures roughly 3/8" at the small end and 1/2" at the large end. Make it easy on yourself and get a standard broach and bushing.
👍 1
Originally posted by dian View Postwhat problems do you have with broaching on the mill or lathe? especially such a small slot?
As for the mill, does not apply.CNC machines only go through the motions.
it work right. It will require a custom bushing as well. Just not worth the trouble...
Keith
__________________________
Not speaking for the OP, but broaching/shaping a slot on the lathe always seems like lathe abuse to me.
i would rather see it the other way, but i gues it depends on what size of machines we are talking about. the lathe rack just seems more robust than a quill feed.
Put the slotter tool in an offset boring head, held in the tailstock
would be more rigid, less strain on the works.
-DoozerDZER
I believe the rack pinion gear in the apron is the weak link there.
-Doozer
JL...............
-Doozer
He has the wrong tool for the job, and that's no error.CNC machines only go through the motions.
