Originally posted by old mart
View Post
View Post
Why the hatred of set-tru chucks? You seem very bitter.
I'd rather dial in the chuck in a minute or so, with positive adjustment, than fiddle-fart around tapping this way and that way, in an effort to get the chuck centered, only to have it move off when tightened. Do you also prefer a "wax chuck" like watchmakers had to use 160 years ago?
The set-tru are very useful, not that expensive when bought used. I got a very nice 4" set-tru chuck for $50 or so. Contrary to the usual set of "stern warnings" from the "experts", they DO repeat well on successive workpieces, so long as each workpiece is not cut from a different piece of mystery metal.
I'd call a set-tru chuck a "poor man's collet set", with the advantage that one size really does fit all, up to the max size the chuck will hold. (naturally, you reset for a different size work, but you'd have to change collets also).... And collets for 2" work are not exactly cheap, even if you can get one, nor do they hold like a chuck at that size.
