My idea was basically to turn the back plate into a 4-jaw, the back plate would be the same nominal diameter as the chuck but would have four slots that held small adjusting jaws.
Dialing in a 3 Jaw Chuck
I must put my mind to a design which allows screw adjustment of the chuck on backplate, but as there are so many variables, it is difficult. The set tru type of chuck are always longer than a standard type which has disadvantages on a lathe with a short bed. One possible design might be 4 grubscrews spaced at 90 degrees with 60 degree ends threaded through the backplate to hit the step in the back of the chuck where the register is. The maximum allowable movement would never need to be more than 0.006" from dead centre.
Here are three chucks of 100mm, 5" and 160mm. The 100mm has 6 front mount 6mm SHCS. The 5" has 3 front and 3 rear SHCS. The 160mm has 6 studs lock washers and nuts on the rear. As the backplate was slightly undersize, the studs are stepped 10mm/8mm (there were some titanium Westland Lynx gearbox housing studs lying about, NOS, that type were replaced with steel as they were not up to the job).
Originally posted by old mart View Post
Another thought I had is instead of cone-points, maybe there is a way to use screws with eccentric turned tips? The eccentrics would push on the inside of the register diameter. In theory, you could adjust just one or two eccentric screws to push the chuck over and then re-tighten the backplate screws.Last edited by Galaxie; 12-24-2020, 02:34 PM.Location: Northern WI
Yes, the idea of eccentric ends is well worth considering, they could be a bit larger than the grub screws as there is likely to be more room inboard of the register to fit them. The finer details of exactly how the eccentric would be made aren't there yet, but they have to be fairly stiff to turn, and 4 are better than 3.
I could definately fit the eccentrics to the 160mm chuck backplate, but there would probably not be room with the 5" and 100mm as I have made them locking on the threaded spindle and that uses up the space. The 160mm has not been modified.
Not sure how the eccentrics would be more sensitive than a fine screw, while still having good range, but it is an interesting thought.CNC machines only go through the motions.
A throw of 0.020 would be 0.020 per half turn.
a 24 tpi thread is equal to that, and anything finer such as 32 tpi would do better. Total movement is unlimited, of course. Finer threads would be possible, and if the backplate is steel, would be practical.CNC machines only go through the motions.
If you have a three jaw chuck that is more than 0.004" runout then it wants either some serious work or downgrading to a welding fixture. The movement should be as small as you can get away with, a chuck with 0.003" runout is common, and if the adjustment was 0.006", it would be more than enough. My guess at 0.020" eccentricity may be too big.
JT, I don't understand where the thread pitch comes into the equation, could you explain?
The pitch gives the advance per turn (360 deg). Your eccentric gives full travel in a half turn, 180 deg.
So comparing on the basis of advance per turn, or alternately, on thou per degree of rotation, makes sense to compare sensitivity of the adjustment.
Having a bit more adjustment is good, I do not think 0.010" or 0.020" is too much. It's not always for the chuck, although that is the main issue, of course.CNC machines only go through the motions.
Originally posted by Bented View PostA number in the Fibonacci sequence would be preferred such as 21 rather then 20.
A thread lead of 0.04761904761904761904761904761905 has advantages over a lead of .050CNC machines only go through the motions.
Another option on old mart's train of thought is to have the adjustment set screws parallel to the back of the chuck, threading into the "boss" on the front of the backplate, with the Allen key end just touching the inside rim of the back of the chuck. You'd have the thickness of the set screw from the thread ID to the inside of the hex to work with. The use a ball end mill or grinder to create a groove in the backplate for the Allen key/ hex wrench to go. Dimensions will be pretty tight, but it's an idea.
