Fun with my shaper!
I don't know, every time I see a shaper I think damn that thing would be really cool if you put a CNC on it! Three axis, one for tool rotation. Gears internal and external, square, rectangular, heart shaped holes and the part that would fit that hole. Then you really don't care how long it takes.
YouTube videos (mentioned by BCRider):
Metal shaper shear tool
First attempt at grinding and using a shear tool for the shaper. Be sure to click through at various times to see the different views and depths of cut.
Enjoy the videos and music you love, upload original content, and share it all with friends, family, and the world on YouTube.
Grinding A Shearing Bit for the Shaper
Grinding shaper tools.
Antique Queen City Metal Shaper / Shear Tool
Shaper Shear tool trials
Shaper and Lathe Tool bit grinding
The first version that I uploaded was quite unsatisfactory. I deleted the original and uploaded this remastered version. I apologize to the people who left t...
Metal Shaper Action - PK Douglas Finish Cut with Shear Tool
I filmed this about a year ago. The PK Douglas shaper using a shear tool for finishing cuts on a piece of 1045 medium carbon steel. When the tool is travelin...
Shaper. Shear tool.
24" Queen City shaper shear tool
Originally posted by garyhlucas View PostI don't know, every time I see a shaper I think damn that thing would be really cool if you put a CNC on it! Three axis, one for tool rotation. Gears internal and external, square, rectangular, heart shaped holes and the part that would fit that hole. Then you really don't care how long it takes.
I want to modify mine to allow for vertical movement. But given the stout support leg I'm thinking that it'll be wise to limit the DOC and amount removed with each pass.
And why move the table vertically? The normal flow calls for using the slide on the ram for vertical cuts. But the dainty little thing on mine only has roughly 2.5 inches or maybe a touch less of usable travel. And of course it needs to be bumped by hand each pass. It would be nice to allow for auto feed in the vertical direction. The trick would be in taking even more care to be sure one doesn't run the table up too far and let the ram run into something hard and heavy. Or perhaps start the cutter at the lowest point of the cut and work "up" by letting the table drop down and away from the ram.Chilliwack BC, Canada
Originally posted by BCRider View Post
That might be a bit tough since the smaller models at least are not set up for moving in the vertical direction. Most have sliding table supports to avoid tipping under pressure. Or at least to help the vertical ways resist those tipping forces.
And why move the table vertically? The normal flow calls for using the slide on the ram for vertical cuts. But the dainty little thing on mine only has roughly 2.5 inches or maybe a touch less of usable travel. And of course it needs to be bumped by hand each pass. It would be nice to allow for auto feed in the vertical direction. The trick would be in taking even more care to be sure one doesn't run the table up too far and let the ram run into something hard and heavy. Or perhaps start the cutter at the lowest point of the cut and work "up" by letting the table drop down and away from the ram.Location: The Black Forest in Germany
I think it's likely the next level up from my Alba that frequently has auto feed on the ram's slide. Mine is purely manual though.
On the table travels the square used on the ends is the same in both cases. But the vertical travel shaft has the wrong size diameter to put the toothed auto feed wheel onto it. It'll only take putting on a sleeve mind you. Just haven't gotten around to that part yet.Chilliwack BC, Canada
Originally posted by 754 View PostMost shapers are rated by the cube size they can machine..
on good ones at least 2 feeds...meaning 2 surface in one setup , at times...
like machining 2 sides of an angle plate...........try that on your milling machine..
Sarge41
