1) An INSIDE deburring tool. By inside I mean this: let’s say I drill a hole into a piece of tubing. I want to remove the burr that is on the INSIDE of the tube.
2) Brazing shim stock, i.e., used for furnace or torch brazing. A piece of shim stock is placed in the joint, The joint is clamped together and heated to the melting point of the shim, the shim melts and collapses and voilà, a neatly brazed joint.
