If everything was just perfect it might work with small clearance, but it is no easy feat to machine 10 leads in each direction on a nut and a bolt with enough precision so that they can be fitted together without a lot of clearance. I would bet quite a lot that he's way under standard pitch diameter on the bolt and/or way over on the nut. In fact you can see it in the way that the head of the bolt has quite a lot of up and down wiggle (and resultant clanking noises) while he's threading it in and out. And we already discussed the included angle mismatch - though that could still be tight on clearance at it's tightest point.
Any way you look at it, this is no more than a conversation piece. It would be next to useless in any real world application. The threads would be extremely weak and lack any kind of resistance to axial force.
Thread in Two Directions At Once
I believe that the fit has to be loose as the nut has to be moved slightly axially to enable it to turn in one direction and in the opposite direction to turn the other way. Watch the video closely and you can see him doing just that.
I don't see why a loose fit is required for this to work. They may be loose, per the previous discussion, but if they were perfectly produced the concept should still work perfectly.
Its very clever, it only works because the fit is extremely loose.
The equivalent of ½ the pitch diameter tolerance as it would equate to ½-angle of the thread. Like I said, not very clear and sort of a gray area. That is one section that could certainly use a re-definition, for sure. They sort of lumped several things into one there, not very good.
Originally posted by eKretz View PostYes, there certainly is. They are not particularly common in reference materials though, nor very easy to find. Here is a screenshot from an old National Bureau of Standards handbook on threading showing a column for "Deviation of Half-Angle" for various inch threads. These fall under a sort of general tolerance on pitch diameter. Some percentage of the total in the published pitch diameter tolerancing is allocated for such errors. It seems to be sort of a gray area. Note that the total at a given "perfect" pitch diameter can not exceed that angle deviation - in other words the given tolerance for the angle is only correct if the pitch diameter is theoretically perfect. If the pitch diameter deviates from theoretically perfect, the tolerance on the angle is reduced by that same error percentage. From what I understand this also applies to lead error - so the only way the angle deviation in the table will be correct at that given value would be if thread lead and pitch diameter are both dead nuts.
yes, the russians: https://youtu.be/NZc-gqSIL4w?t=272Last edited by dian; 12-21-2020, 06:56 AM.
What is it with these Soviet lathes and threading super coarse? 48mm lead? Nearly 1/2 TPI on 14"? 16"? lathe? Must have been some big deal about multistart threads in the USSR or something.
Kinda jelly though. Seems like a nice machine.
It gets more complicated when the helix angle is not only dependent on the pitch and the number of starts, but also the diameter of the thread.
Yes, there certainly is. They are not particularly common in reference materials though, nor very easy to find. Here is a screenshot from an old National Bureau of Standards handbook on threading showing a column for "Deviation of Half-Angle" for various inch threads. These fall under a sort of general tolerance on pitch diameter. Some percentage of the total in the published pitch diameter tolerancing is allocated for such errors. It seems to be sort of a gray area. Note that the total at a given "perfect" pitch diameter can not exceed that angle deviation - in other words the given tolerance for the angle is only correct if the pitch diameter is theoretically perfect. If the pitch diameter deviates from theoretically perfect, the tolerance on the angle is reduced by that same error percentage. From what I understand this also applies to lead error - so the only way the angle deviation in the table will be correct at that given value would be if thread lead and pitch diameter are both dead nuts.Last edited by eKretz; 12-20-2020, 05:09 PM.
- Likes 1
is there atually a tolerance range for the 60° angle on threads? i dont recall seeing anything like that.
The threading insert shims only go to about 3 degrees which helps mostly with the tool clearance.
Originally posted by dian View Post
interesting. so if i tilt the round shank cutter in the holder im not producing threads to specs? i would have to use a 60°+ point? and all the inserts that get shimmed? are they larger than 60°?
If you mean a plain single point threading tool with a round shank, yes that's correct - but it will take a fair amount of rotation to cause the produced angle on the threads to change a lot. We were talking about multiple lead threads with a very high lead... For a single lead thread the tool wouldn't need to be rotated much, but yes, every bit you tilt the tool will change the included angle of the cut thread.
As regards the other inserts that use shims - Check the threads produced and see! You won't see much without a comparator probably unless they are tilted pretty far.
A guess, here, but I think the helix angle on the Russian's thread is about 17 degrees. As an example of the angle changing, you can cut a piece of card and fit it into a vee block Now rotate the card and watch the angle of the gap change. If you had a cone with a 90 degree end and fitted it in the vee block, it would still fit if it was rotated.
I don't think so... The included angle of a thread is always measured on centerline and parallel or rather square to the workpiece axis of rotation - not inline with the helix angle. The router will cut on centerline as long as it's positioned correctly, just like the single point tool. 60° is 60°... Or whatever angle he used. If the router bit and the single point threading tool are ground to the same angle, they will cut a close-fitting mating thread. If you cut that shaft in half and measure at centerline, you still have a 60° included angle - it's physically impossible for it not to be if the tool is ground at 60°.
The angle of the tool doesn't change just because a thread has a steeper helix angle... The single point tool should still be flat on top to maintain an accurate included angle - you don't generally change the top rake angle on a threading tool for larger pitch, only side clearance angles. In extreme cases, the top rake angle can be altered - but in that case the tool's included angle must be reground so that the included angle formed by the tool is still dimensionally accurate at centerline and square to the axis of rotation. This involves compound angles and is a large pain in the you-know-what without something like a tool and cutter grinder.
Your reasoning about tilting the tools is exactly why it is not done that way. The included angle is measured square with centerline/axis of rotation and not aligned to the helix angle for that very reason.
The router bit may alter the included angle slightly at high helix angles, I'll give you that one. But I think it wouldn't be a lot, and probably inconsequential for the most part until it gets to a helix angle over at least 30°. The relief angle of the tool must be greater than the lead angle of the thread to prevent that. That is why, for external thread milling a tool is generally used that is like a side milling cutter from a horizontal mill, and the spindle of the machine is sometimes kicked to match the helix angle. Otherwise you need excessive clearance angles on the tool. This does necessitate a different included angle on the tool though.
It's a complicated subject. Suffices to say that on relatively low helix angles it's not that much of a difference - might well fall within thread tolerance. On very high helix angles it could be a problem.
