DRO for the surface grinder
  • DRO for the surface grinder
    I just recently installed a inexpensive imported DRO with glass scales for my mill. As it is suppose to be a 5u scale, would this be adequate for my Harig Surface grinder. I currently us a .0001 indicator and it works fine returning back to a project from a redress the DRO certainly would help.
    skipd1
    Higher resolution scales are only $15-$20 more on those import dro's. I got the higher resolution one for the cross slide on the lathe. I would get the higher res scale at least for the down feed if nothing else.
