O/T: Tool Opinion. HILTEX 1/4" Hex Screwdriver Bit Set
  • O/T: Tool Opinion. HILTEX 1/4" Hex Screwdriver Bit Set
    Normally dont like to give opinions to a bunch of Machinists, cause you know.
    But I bought these cause my 1990s craftsman set is getting real thin.
    I had a slotted screw (blade) that was stuck but good. It was a thin slotted screw head and I didnt want to wreck one of my good screw drivers.
    So I chucked up the magnetic holder in my makita impact driver and loaded it with the smallest blade bit and leaned in on it. Impact hammer was set to high and it was rockin and rollin. Screw never came out, of course.
    But the bit never left the slot and didnt even get a scratch much less shatter. Yeah, I have had them shatter.
    So, for ten bucks I cant even buy 61 inches of high carbon hex in 1/4". But you can get these. JR
    FYI. No need to bash it in re china and all. Its a good tool.
Name:	HILTEX 10060.jpg
    Lowes and Home Depot carry this SKIL set, and they are pretty good.
    DZER
      I have a master set by Chapman. Not cheap, but they are top notch. Precision ground and hardened American tool steel. I broke a ****load of bits before these.
      Our largest Chapman set includes everything #5575 Master set has plus SAE & MM Ball Allen, Robertson square head, and JIS bits! Equaling 68 screwdriver bits, 2 extensions, 2 spinners, handle, dipped ratchet, and customizable set case! Made, hand assembled & inspected in Durham, CT with USA materials.
        https://chapmanmfg.com/products/1000...51a45b66&_ss=r
        Right? I did not want to subject my thin blade, good Drivers for this exploration.
        FYI. It was fun. I expected it to jump out of the slot. First couple of taps.
        "Flat screw" was not moving and the bit didnt tear out and ruin the screw top. JR
          Left hand thread?😀
            Originally posted by RMinMN View Post
            Left hand thread?😀
            She is an angle grinder head (thread) now JR
              Awhile back at Princess Auto in the surplus section I came across a manual impact driver that takes 1/4" bits and I've used it a couple of times where I couldn't get a regular screwdriver to do the job so I'm quite happy with it.
                Left hand thread?😀
                Didnt think of that.. No, it was some German Speaker Drivers. JR
