interepted cut with boring bar
Even with that short stickout you might take the extra step of wrapping some solder around the bar to dampen it. Or lay on a strip of that sticky window sealant, something like that. I doubt if the magnitude of any oscillations would damage the cutter, but it's pretty quick to add this damping. Solder can still be used later, or just kept for damping boring bars, etc. Plus it won't pick up swarf like anything sticky will.I seldom do anything within the scope of logical reason and calculated cost/benefit, etc- I'm following my passion-
[QUOTE=rogee07;n1917552]
will be boring a 2.5" hole trough a .75" thick plate of 8620. on the back side of the plate several .25" features have been cut on the back side of the JR
We want to see/So, lets see the "features"
What are theu? We want to see?
Show us the several features in .250" off the deck..
I love great machining. It makes me want to get to the garage (shop) an do... Do anything really.
Thanks.... JR
Yep, machine rigidity counts. A very slightly loose compound - even though you thought it was tight, can have some disastrous results.
This was my solid carbide 1/2" bar last week. Boring a 1.25" dia hole, 2" deep in A2, about a 0.030" doc. About 3/4 of the way in must have hit a hard spot in the material. The tiniest bit of lift in the compound and Bam! ....scratch one expensive boring bar.
If you have a bigger bar, by all means use it, but with the minimum stickout the 3/4" bar should be fine. Having a choice of inserts allows you to select the best one for that particular job. Make sure your compound slide is not overhanging either. I have got away with using carbide inserts for aluminium on interrupted cuts on steel, but I took care to keep the depth of cut low.
Sad to see your poor carbide bar, Peter, I have made some by buying carbide stock and silver soldering on the end of a cheap Chinese steel boring bar. Of course, a means to hold the round shank has to be factored in. The only carbide boring that I have broken so far was a home made 7mm which I crashed into a chuck.Last edited by old mart; 12-24-2020, 10:59 AM.
Originally posted by darryl View PostTundra- I bet those sockets work great nowIs that part of a punch set?
Originally posted by 754 View PostTUNDRA I call jobs like that GRAUNCH and ROLL.....
Originally posted by Lew Hartswick View PostFor interrupted cuts just use HSS tooling. Like this. :-)
...lew...
I have a small lathe and mill in my home shop. Interrupted cuts are bad, so I would scribe a circle and endmill it close as you can. Then bore the hole. I hog on the mill before the lathe, because it's not a beast. I never liked interrupted cuts on a lathe. You can end up wearing that carbide insert ?
