Gearotic experience?
  • Gearotic experience?
    Has anyone here used this program?
    I'm wondering if it is able to do worm gear sets?
    Thanks, Sid
    It doesn't do worm gears or worms. It does do a bunch of different timing belt pulleys as well as spur, helical, knuckle, herringbone, and bevel gears. I use Autodesk Inventor for worms.
      I used it to make helical gears for my .357 gatling gun build, worked fantastic. Don't know about worms for sure.
        FreeCAD does worms but I don't see worm gear. I think someone who knew a lot more than I could make the worm gear from an involute spur which it does. It does not seem like a simple operation.
        OK, I found a tutorial for worm gear generation. https://www.youtube.com/watch?v=SKy8Y9P8lxo
          I have gearotic. Not happy with the developers ability to fix issues, same guy that wrote Mach3/Mach4, why I won't touch that software. Gearotic is unable to spit out a useable 3d CAD model for use with Solidworks or Fusion, his response is, "Well, I followed the documentation". No intention of ever fixing it.
            No experience with Gearotic, but you can make standard or custom
            worm gear sets with Vectorworks, or McMaster has CAD models of
            worm gear sets, if that might help.
            Larry
              Heck, you can do worms with any cad system that supports a helical cut path. What's the issue? Well, you DO need to know the geometry you want, but..............
              Then some work with boolean subtract and you can do a worm wheel
                Click image for larger version  Name:	Vectorworks.jpg Views:	0 Size:	20.8 KB ID:	1917836 Click image for larger version  Name:	VW Properties.jpg Views:	0 Size:	99.4 KB ID:	1917837 Click image for larger version  Name:	Worm.jpg Views:	0 Size:	48.0 KB ID:	1917838
                Last edited by metalfixer; 12-24-2020, 04:23 PM. Reason: Attachments were supposed to go with post, don't know what happened.
                  Originally posted by RB211 View Post
                  I have gearotic. Not happy with the developers ability to fix issues, same guy that wrote Mach3/Mach4...
                  Art Fenerty did indeed write both Gearotic Motion and Mach3, but he was not involved in the massive re-write that is/was Mach4.
                    I certainly can model up anything. I use Creo for a living. But gerotic is pretty quick for the “what if.
                    This gear needs to be 12:1 for the clock, and it has some pre defined parameters that it would be nice to not have to change if possible.
                    Sid
