I sometimes wonder about the rpm limitations when running a spindle with a large bore, which of course means larger bearings, and then chucks of any kind. The larger the slower, but what's an example of a chuck, for instance, that has a large diameter AND a high rpm rating?
How fast can you turn a spindle with a large bore- if you don't consider using a large diameter chuck at the same time? Can it be as simple as a bearing limitation, or is it the ability of the chuck jaws to stay in place under tension and at high speed- and the ability of the chuck body to stay in one piece at speed?
I know you pay a price to operate a large bearing at high rpm- the heat produced. You pay for this energy to begin with when you run at high rpm, and you are forced to take measures to keep a constant temperature for proper operation of the spindle- which means a design for a high cooling ability would be needed.
Do they even make a machine that is optimized for large bore/high rpm? Or would that just be stupid?
