How to unpack and assemble your new lathe!!!
  • How to unpack and assemble your new lathe!!!
    Unpacking your new lathe....
    https://youtu.be/vSEq2y_NBf8
    • Height Of Center: 200 mm
    • Spindle Bore: 51 mm
    • Admin Between Center: 1000/1200 mm
    • Bed Length: 6/7 Feet
    • Spindle Speed: 1535 RPM
    • Bed Width: 280 mm
    • Cross Slide Travel: 210 mm
    • Motor : 3HP
    • Headstock and gearbox gears hardened and ground.
    • Bedways hardened and ground up to 400BHN.
    • Turcite B anti- friction material on carriageways.
    • Control panel & magnetic brake (optional available on request)
    • Metric dial on cross slide, Compound and tailstock semi-universal gear box provides inch and metric thread without changing too many end trains gears.( universal gearbox optional available on request )
    • Spindle speeds 48-1535 RPM in 16 H-L nos. spindle speeds.
    • Alloy steel Spindle molesting on taper roller bearings.
    • American LOO type spindle nose available on request.
    Price about US$2500
    I would buy that lathe, the one in the add. Looks like a 14-40 knock off. JR
      Haha, fast forward to 8:55, tightening the chuck on to the spindle with a hammer. No camlock spindle?
        L-taper, which if done right is actually better.
          I love the spindle molesting in taper roller bearings, unless thats a typo by the OP. Looks like the tailstock spindle lock needs a spanner. Does the tailstock bed lock need a spanner too, or the lockimg lever out of sight round the back?
          'It may not always be the best policy to do what is best technically, but those responsible for policy can never form a right judgement without knowledge of what is right technically' - 'Dutch' Kindelberger
            Agreed....but kinda like a beta recorder is better
              LIKE LOL
              -Doozer
              DZER
                Hindustan lathes are pretty good
                but this one is not one of them.
                But the writing is in another language
                so maybe.
                -D
                DZER
                  Only two levers on gearbox makes the number of threads available without fiddling seem likely to be low. Noticed towing eye on the end of the bed.
                    For as often as I change chucks, I would rather just have an A1 taper and stuff the cams.
                      Stack of gears at about 9:20, so no wide range without a shuffle.
                        While it’s out there the L taper always costs more and is harder to find than cam mount. I really wish my Clausing was cam mount rather than the L for that reason.
                          Here is another one for consideration, belt drive, change gear.
                          Less than $1000.
                          https://ravimachines.com/product/lig...ine-banka-165/
                          Check the included accessories.
                          Fit and finish looks better than a South Bend!
                            Less than $1000.
                            And V-belt drive too so at least they upgraded from flat belts. Add a VFD an it would be fine.
                              Did you notice at 8:33 the chuck mounting hardware protruding out the back of the mounting plate? Safety First!!
