Originally posted by JoeLee
View Post
Flame Resistant Fabrics
not shure how much of the stuff you need. curtain is different from machine cover. i would try this.
spark resistant fabric: take some linen (or get cotton bed sheet from op-shop). soak in 10-30% waterglass. preferably let dry in the final shape. it will get a bit hard*, will be water, dust and spark resistant. not much to loose, before spending money on silicon or some space-flight material. if your in a hurry condition with co2.
*will tend to keep its shape
but above all, put the grinder in a corner.
Originally posted by epicfail48 View PostHow flame-resistant do you need it to be? Trapped in a crashed racecar flame-resistant, or just wont catch fire easily flame resistant? Cause plain old denim is surprisingly flame-resistant for a basic fabric, but wont compare to Nomex. That said, if all you need is protection from an incidental hot bit hitting you it could be enough
P.S. Nomex is hot to wear.😰
P.P.S. as a demonstration, for us, a piece of Nomex was held against an OX-Acet flame from a torch (high and direct heat) and it DID NOT ignite but the material crinkled and shrunk up and became stiff. Eventually it crumbled away.Last edited by loose nut; 12-30-2020, 09:29 AM.The shortest distance between two points is a circle of infinite diameter.
Southwestern Ontario. Canada
Originally posted by reggie_obe View PostMight consider welding curtain material, but if you want something smooth and flexible that will catch and extinguish sparks, maybe a good weight of smooth cotton canvas.
JL..................
Originally posted by dian View Postnot shure how much of the stuff you need. curtain is different from machine cover. i would try this.
I found some vinyl material in the shop. It would probably suffice but the back side has that felt fuzzy stuff on it. Not sure about it being safe, even though it would be on the underside.
JL.................
Get some fibreglass fabric, auto body stuff thicker if possible. Maybe from a fibreglass boat builder. We used that to control sparks and for heat insulation while welding. It doesn't burn but will melt if exposed to high heat like direct contact with a torch flame.The shortest distance between two points is a circle of infinite diameter.
Originally posted by loose nut View PostGet some fibreglass fabric, auto body stuff thicker if possible. Maybe from a fibreglass boat builder. We used that to control sparks and for heat insulation while welding. It doesn't burn but will melt if exposed to high heat like direct contact with a torch flame.
JL.....................
Originally posted by Corbettprime View PostJust for giggles and grins, get some clear vinyl sheeting from your wifes/girlfriends favorite fabric store. Available in several weights/thicknesses, very inexpensive.
This is vinyl like what you would for seat covers, car roof tops etc. Has that fuzzy white stuff on the back side. I put it through the flame test and it wouldn't ignite. Just melted a little and stunk some. I guess this is the stuff to use. I will make a custom fit bib / apron to cover what I want to protect on the machine. Will probably have to do it in two pieces to allow the table to move with out bunching the material up. Maybe some velcro to secure it around the column etc. I'll have to play around. Just like putting way covers on your mill !
JL...............
Originally posted by JoeLee View PostThat's pretty much what I have here. Had it laying around the shop and never gave it a thought.
JL...............
Worst case scenario, do you want to be inhaling fumes from smouldering plastic?
I have some of that fiberglass cloth. It's nasty stuff to work with. Breaks down, falls apart and goes everywhere. Unless it's coated with rubber like in a tarp form.
JL.....................The shortest distance between two points is a circle of infinite diameter.
Originally posted by elf View PostHow about a bigger dust collector/vacuum?
And every time I change position of the grinding wheel / head every thing has to be moved and re-positioned and most of the time I just can't do it, again, everything is in the way.
I do have that nozzle set up I made last year that can be positioned directly under the wheel, it works pretty good for dressing, get probably 80% of the dust and grit but not all of it and sometimes it's in the way when grinding so I have to move it out of the way and just let the dust go. I don't like sucking sparks directly into that plastic hose either.
If someone has some pics they would like to share I would love to see them.
It was a real tight fit making this work, but it was the best I could come up with.
JL.................
