Originally posted by andywander
View Post
andywanderer
Thank you for posting the images of the spindles. Neither of my spindles has a flange on the end but a loose washer might serve the same purpose. But if I mounted a stone between the two flanges of the lower spindle in your image, the fastener would be the spindle axis. In my case either an 6-32 or an 8-32 (don't remember). That would scare me - I see the stone whipping for a second or two before the fastener failed from fatigue. I am looking to mount something in the 3/4 inch diameter by 1/4 inch wide as a grinding wheel/stone. Maybe the spindle is intended for something sized like a Dremel accessory.
