The arbor is surely removable, I would just make some new ones with a nut. These are a couple from my toolpost grinder.
Mounting grinding wheels/stones to a taper shafted tool post grinder
I would see whether that spindle extension is removable. Pushing the stones up the taper is a sure way to make mini grenades.
- Likes 3
Originally posted by aribert View PostI have a small tool post grinder with a tapered shaft for ID grinding. How does one properly mount a grinding stone. If a stone slips, it grinds into the tapered spindle, BTDT....
What is BTDT? Some partisan code?
- Likes 1
It would be nice to see some more details, like the other end of the shaft and the name plate on the grinder.
- Likes 2
Are you certain that is not a removable arbor? In some cases the entire length may be removable and replaceable.
it also may be a replaceable quill assembly, in which case you do not have the one for straight shaft / normal wheels.
You might make a tapered ID adapter to fit, with the OD to suit your wheel. The taper might turn out to be something do-able, like same as a taper pin, for which there are reamers.Last edited by J Tiers; 12-29-2020, 12:54 AM.
I have a small tool post grinder with a tapered shaft for ID grinding. How does one properly mount a grinding stone. If a stone slips, it grinds into the tapered spindle, BTDT. Are there special tapered ID stones? Could I make an aluminum tapered bore sleeve and then bond the sleeve into a larger ID stone? The TPG has a second spindle asm for external grinding where the stone/blotter is pushed against a flange and a nut/washer on the opposite side of the stone/blotter.
Tags: None
