Reading about icebergs floating down iceberg alley got me wondering if you could harness one of those things. Back in the prairies you could find ice houses, which were just piles of ice bricks inside a straw shelter, basically. You could have ice all summer if you harvested enough ice from your frozen winter. In this case, you could potentially tow an iceberg into a lagoon of sorts, then use it for keeping cool in the summer.
Speaking of cool, I've been wondering if you could use a pelltier device with direct sunlight on one side, and cooling by some means (melted iceberg water perhaps) on the other side. Would you get enough heat input to create a sizable temperature difference across the device, or would you have to concentrate the solar radiation?
I know these devices are poor insulators, so you're always going to have a steady flow of heat across them, which is a loss. Can you make anything reasonably efficient as a power generator from a grid made of these devices?
