Originally posted by Dan Dubeau
View Post
If you have a big mill you could rip a bar down into fingers in no time and then just cut them to width. Then finish up on the grinder.
Your apron design is the same as mine, beveled on the inner top edge and so is the finger bar or plate.
They later changed all that to cut back on all the machining. They use the square edge of the 3/4" bar, both apron and finger bar and changed the location of the pivot point to make the edges meet.
The handles they used are 3/4" square bar. the ends are turned round to accept a rubber grip. Some of the ones I've seen use hex rod for handles. Don't know when the change was made, but your two machines are of the same vintage as mine. Mid 70's to mid 80's so I've been told by the company. According to them the color tells more than the SN# as far as MFG date.
PS............. nice job on the prop ! OMC / Johnson Evinrude?? Are you going to fix it??
JL..............
