View Post
Pegboard bins?
I have some 16ga pegboard panels, with good pegs, that actually fit the holes, it will support substantial weight. For that matter the 1/4" tempered Masonite pegboard is also good, if it's installed correctly.
Shelves and drawers are great,*IF* you have room for them. My homeshop is tiny, I have just two 4x6' sections of empty wall left and there are machines parked in front of those.Chilliwack BC, Canada
Originally posted by OaklandGB View PostPegboard is perfect! Every time I try to pull a screwdriver from my pegboard holders, it detaches, and the wire holder disappears between the wall and the back of the bench.I bet there are a dozen of those back there if I ever crawl under and look. The holes are getting wallowed out too.
A replacement storage system will definitely not include pegboard.
French cleats?
They were invented for high class department store displays where lots of space is available and eye appeal is the primary consideration.
If you think that things like pegboard are a waste of space, French cleats have that beat by a country mile. Sorry, my shop may have a few square feet of pegboard, but it will never have any French cleats.
Originally posted by Galaxie View PostSomething else to consider is French cleats.Paul A.
I've never seen a problem with insects of any type behind mine. But I never close up the area behind, it is always open at top and bottom. They apparently don't like that. But I have very little problem with "bugs". Saw ONE "bug" (so-called) this year, and it was a huge roach, but it apparently came in when the outdoor tropical plants came in for winter.
The only critters I allow are spiders and centipedes. Both eat "bugs", so I let them do it. The spiders may put a web back there, but I am fine with that.
BTW, cockroaches are not actually "bugs", they are in a different classification.Last edited by J Tiers; 01-09-2021, 02:15 AM.CNC machines only go through the motions.
Originally posted by Be_Zero_Be View PostI put my organizers on a lazy-susan.
It gives a very high density storage for a small footprint.
Also, because it rotates, I tend not to stack stuff in front of it to block access.
I also made racks for my small organizers.
Wanted to comment late on using pill bottles etc for smaller storage in the bin boxes. I prefer 4 mil ziplocks in various sizes. No wasted space, pick the right size for the fastener, and won't roll off the workstable or spill. I get the ones with the white label writing field from Mcmaster. I used to use dividers in my little plastic drawers of fasteners #10 and under, now there's just a pile of 2"x 4" ziplocks. Also makes it easy to reorganize.
Originally posted by gellfex View PostI have a mini version of that. Yes, it's very efficient.
And I agree on the wasted space issue. Pill bottles and old jars are better than nothing. But it does waste the room where the round containers fit against each other. And if there's only a few things in a bigger container it wastes even more space.
For smaller hardware under 1/4" I went with the hinged lid storage trays with the combination of fixed and slotted separators. I can size each pocket to suit the amount and size of fasteners. And all the sizes and head styles are right there to see. And they stack neatly on a shelf. Or for other items neatly in a drawer.
I must have up around 30 of these adjustable organizers with hinged tops in the 11x7x1.4 inch size in a few different brands. The style and size that is the most common for me is THIS ONE FROM HOME DEPOT. From time to time they come on sale in two packs for $7 or three packs for $12 or so. I stock up when that happens so I've always got one or two empty ones on hand. There's likely around a dozen to 15 of these with the hinged black catches from HD. And another dozen with the "flex style" catches from some earlier supplier from years ago.
I also have four of THESE HDX ORGANIZERS. These are larger than the trays above but again very handy and stackable and the price is right at only $6 each. Quality is good on them too. I'd totally trust carrying them around filled with screws, nuts and bolt, nails or whatever you have to carry. I wouldn't throw them around but they are tough enough to stand up to normal handling without any issue.
- Likes 2
