i have about a dozen different propane burners, some are bought, some self made. none of them will heat a small strip of sheet metal to more than medium orange (might be 900°c). even the mapp torch is no different. how come everybody on youtube is melting cast ron in crucibles and bringig steel up to welding temp.with propane?
flame temp. of propane is supposed to be 2'000c and i can adjust several burners to extremely lean (where the flame separates from the flare and goes out).
does anybody have a propane torch that will heat steel to a white color or even melt it?
edit: i became interested in this after my black-smith-friend bought a "profesional" double burner kiln and couldnt use it for damascus welding as intended.
