This is what started this whole issue of tramming the mills head to such precision. It was this electronic edge finder. When I would zero it off the fixed jaw of the vise and move to my position to drill a hole, I was consistently off my mark by .005 - .006. When I would drill through something I was noticing that there was a difference in distance from the entering hole and the exiting hole. The thicker the part the greater the error. I used ground test blocks to eliminate as much error as I could in tracking this down. I thought that the error was in the probe. Come to find out the error was in the head. It had some slight nod. Less than a half a thou. The error was being amplified by the length of the probe. Once I trammed the head to within a tenth, and it wasn't easy the error disappeared.
JL.....................
