I have never used a mister. The one in the picture came with a lathe I got. I have submersed what appears to be a pick up tube with a filter on the end in a container of coolant, and attached the air hose to lowish pressure air. The valves do work, but it appears to be blowing air back into the coolant rather than sucking it up. I'm missing something simple and obvious? Do I need to somehow prime the line first? Or what? Thanks!
MIster question
On the ones I have you need to twist the end of the nozzle to allow liquid through. If the nozzle is 'open' and there is a blockage in the tip or if you put your finger over the nozzle it will blow back into the reservoir. Mine are Noga, yours looks a bit different but I'd start by making sure the nozzle is clean.Southwest Utah
I feel air coming out, so it does not seem to be blocked. And I can adjust how much air/pressure with with the valve(s). Just no coolant, and bubbles coming up in the coolant tank instead."A machinist's (WHAP!) best friend (WHAP! WHAP!) is his hammer. (WHAP!)" - Fred Tanner, foreman, Lunenburg Foundry and Engineering machine shop, circa 1979
I do have a pump and tank for flood (not yet hooked up either) but I'd like to know that this thing works even if I don't end up using it."A machinist's (WHAP!) best friend (WHAP! WHAP!) is his hammer. (WHAP!)" - Fred Tanner, foreman, Lunenburg Foundry and Engineering machine shop, circa 1979
Originally posted by mickeyf View PostI The valves do work, but it appears to be blowing air back into the coolant rather than sucking it up. I'm missing something simple and obvious? Do I need to somehow prime the line first? Or what? Thanks!
I've got one of the Noga misters and, now that I've figured it out, it works great. When I first got it I ran it
through a regulator with quite a low pressure and with a high intake of the coolant. It created a lot of
mist that hung in the air--you could really smell it and feel it when it was running--didn't like it at all!
After a while I figured out that it was the blast of air that really mattered. I now run the thing on full pressure
(around 100 psi) with a very small intake of coolant. The blast of air blows the chips away really well and
does a surprisingly good job of keeping the tool cool. The tiny bit of coolant that it uses is just enough to
"wet" the tool so it's not running dry. The odd time I'm running something hard like SS or 4340 I'll adjust it
to use a bit more coolant but for most stuff it needs very little...Keith
__________________________
Well, I may try it as a "air only" nozzle then, but so far I am getting NO COOLANT AT ALL and that's what I'm scratching my head about."A machinist's (WHAP!) best friend (WHAP! WHAP!) is his hammer. (WHAP!)" - Fred Tanner, foreman, Lunenburg Foundry and Engineering machine shop, circa 1979
