The back of this chuck doesn't seem to have a tapered register for the backplate. (snuck in a little Germanthere.) Is that normal? I can't believe only the mounting bolts are used to register the chuck to the back plate.
lathe chuck with four jaws that has a scroll and individual jaw adjustment?
Just for the record, not all combination chucks are scroll chucks.
I have an old Skinner four jaw, about a ten inch. The jaws are all operated by full length screws, which cannot be disengaged from the body of the chuck. Just like a standard independent four jaw. Each of the screws has a spur gear near its outer end, which engages with a large ring gear out near the circumference of the chuck. Turn any one screw, and they all turn.
So, how can it function as an independent chuck? Simple. Underneath the ring gear is a separate ring with ramps that mate with ramps built into the chuck body. A screw knob on the back of the chuck allows you to rotate that ring a few degrees, which will raise or lower it on the ramps - thus engaging or disengaging the ring gear from the jaw screws.
I think that it’s actually a stronger design than a scroll chuck, but there is a compromise. Each of the spur gears has maybe 24 teeth - I haven’t counted - so if you need to do any really fine tweaking in the independent mode you will likely have to tweak a jaw or two back again to get the ring gear to mesh. But then, if the top jaws have been ground accurately at any one setting, they should be accurate at all settings. The ring gear won’t wear or shift as a scroll does, and should be more accurate.
Originally posted by Black Forest View PostThe back of this chuck doesn't seem to have a tapered register for the backplate. (snuck in a little Germanthere.) Is that normal? I can't believe only the mounting bolts are used to register the chuck to the back plate.
I dont think a register needs to be tapered, it just has to fit.
I made a drill extender for a corded drill . 1/2 cold roll about 6 inches long , goes on threaded spindle.. register lips.. it works great ...runs straight, leave it on all the time.,
Black Forest,
German language- difficult language.
I as a native speaker -German- have the complete correct grammar also not in use. Is it now "(der)The brook" or "(die)The brook" A brook is a very small river.
The much bigger problem are, the many Anglizissmen in the German language.
Here in the southwest, the French language has also left its mark.
With you in the Black Forest, the Alemannic dialect also plays a very large role.
With you in the Black Forest, the Alemannic dialect also plays a very large role.Location: The Black Forest in Germany
In the UK, we have loads of dialects, some of which are difficult to understand. There was an electrician from Wolverhampton installing something at work, and I thought he was speaking a foreign language. I even had difficulty understanding what somebody from Southampton was saying. The funny thing is that everybody in the country can understand the standard English spoken by a newscaster on a national channel.
