Originally posted by lovemesomemachines
View Post
Shop Crane Modification
Are you referring to what is commonly referred to as a "cherry picker" or engine hoist? What are the dimensions on the hydraulic cylinder? Rod diameter and piston diameter? Cycle time you want to achieve? 12v or 24v hydraulic packs are available with manual or electric valves and they are not very expensive. Correct me if I am wrong but I think you want to have a good tactile feel to the control of the ram for positioning purposes. If so go with a manual valve not electric. I think the cylinder on your typical engine hoist is a single acting cylinder just like a hydraulic jack, correct? The power pack for a hydraulic tailgate would work. Do you want it to be battery powered or are you OK with it being tethered to an electric cord? Also think of catastrophic failure of any of the components and those implications. A hydraulic jack is quite reliable in terms of not failing quickly. Once you introduce more components such as hoses and valves, etc. you need to over spec everything for safety reasons. You probably know all this but others might not that is why I mention it.Location: The Black Forest in Germany
- 1 like
Black Forest...Yes, this crane can be referred to as a cherry picker or engine hoist [https://www.harborfreight.com/2-ton-...ne-69514.html]. The dimensions of the cylinder are very approximate, taken with my tape measure -
Cylinder height: 21.9375 inches (without the mounting bracket/hole).
Cylinder diameter: 3.25 inches.
Cylinder ram diameter: 1.25 inches
Yes, the cylinder on the crane is a single acting cylinder, at least it looks like it is. At present, I'm not interested in it being battery powered. I like the idea of the electric cylinder that member Bented suggested. I'm waiting on a response from the company to see if there is a replacement for the hydraulic ram on the crane. The only drawback for something like this is, and I can see it coming, price! Once I get a response, I'll post back.
Originally posted by Arcane View PostEngine hoists are NOT cherry pickers.“I know lots of people who are educated far beyond their intelligence”
Lewis Grizzard
