I would think that are not intended to torque up things, but are for speeding up the fitting and removing of nuts in confined spaces where your ratchet only manages a few degrees at a time.
Flexible drive / bit holder that lasts?
Originally posted by old mart View PostI would think that are not intended to torque up things, but are for speeding up the fitting and removing of nuts in confined spaces where your ratchet only manages a few degrees at a time.
- 1 like
Originally posted by Lew Hartswick View PostYep ! You don't think those Chinese put satellites up and build Nuclear armed rockets with the tools the US imports do you ??? :-)
...lew...
- 1 like
Like I've written previously, the stuff produced for the domestic chinese market, is infact worse on average than what is exported (verfied by expats living in china). As was found out on a wider scale with the mask shortages and they started sending stuff meant for domestic hospitals to western countries.
I guess the Chinese can make good stuff, if you really harang them about it, if you got inspectors in their factories and check every delivery sorta thing. But the moment you stop, they try and save money and cut corners, it's been explained that it's a deeply ingrained cultural thing and something everybody simply does, it's expected and not even something to feel shame over if you get caught. Their own government can probably put a whole lot more pressure than that to scare the factory into complying with their specs.
But I don't buy chinese because I think they can make good stuff, I know it's mostly ****, but it's cheap and might work good enough, that's the only reason ever. If I had to spend serious money on something, china wouldn't even be on the list.Last edited by DennisCA; 01-14-2021, 02:44 AM.
