Radius Gages any users?
That's one of my nice to have but really don't need to have items that stays in the bottom of the box. Lots of times I've almost completed something by improvising before I remember I have the set. Don't plan on parting with them, though. They don't take up too much space.
Used them a lot on an optical projector, ready made templates for radii on extrusions, hardly ever since, I had mine on a key ring thing for small radii, not as fancy as those ones (Moore and Wright)
used them for drawing too, though the plastic ones with the centre lines are better
mark
I've used them a lot over the years for checking radaii well as grinding tool bits. Also for scribing a line on a piece that I need to belt sand a certain size radius on.OPEN EYES, OPEN EARS, OPEN MIND
I have a couple of sets, one has internal and external radii from 1/32' to 1/4" by 64ths but it's missing the 1/32 external radius gauge which I never noticed when I bought it. I've never needed to use it so that hasn't been a problem. I have another one that's just an oblong plate with notches around the outside for external radii from 1/8" to 1" by 1/16ths and which also has a 11/32'' thrown in for good measure. I may have used that one a couple of times.
I also have a third set for internal radii bearing the name B. Greening Wire Company Limited. It's a very strange gauge set...it has: 1/4 + 1/64, 5/16 + 1/64, 3/8 +1/32, 7/16 + 1/32, 1/2 + 1/32, 9/16 + 1/32, 5/8 + 1/32, 3/4 + 1/32, 7/8 + 3/64, 1 + 3/64, 1 1/8 + 3/64 and 1 1/4 +1/16. I have absolutely no idea what that gauge set was intended to measure and I bought it just for curiosity's sake. It and the other two sets I mentioned were cheap and I bought them just to be able to say "Yes. I have radii gauges!"Location: Saskatoon, Saskatchewan, Canada
One of those tools that doesn't get used very often--in the average shop, anyway--but comes in damn
handy when you really need it. I have two sets that go up to 1" or something like that; I'd have to look
to see for sure. Probably use mine most when I'm reverse engineering a part; makes it easy to check
any radii that need to be duplicated...Keith
__________________________
