I have a 1950 Walker Turner bandsaw (14 inch). The motor (1/2 hp 110 volt) is making a bad sound, I assume its the bearings. Any members near Reno NV know a good motor shop? Ideally I'd like to get this original motor refurbished rather than plop a modern piece of crap in there. So I'm looking for a shop that knows how to fix/rebuild and not just recommend a new motor.
Motor Refurb Recommendations Reno NV
I'm not even in the same country, but I'm guessing that refurbing that motor might cost as much as a pretty decent new one. Motor bearings are generally inexpensive ($10-ish, or less) and easy to replace - I've done dozens of them. I'd confirm that the bearings are the issue (i.e. not a bent shaft rubbing) and if so look at replacing them myself. But then, I'm a tightwad do-it-yourselfer."A machinist's (WHAP!) best friend (WHAP! WHAP!) is his hammer. (WHAP!)" - Fred Tanner, foreman, Lunenburg Foundry and Engineering machine shop, circa 1979
- Likes 3
Plus 1 on the do it yourself recommendation. A single phase motor is very simple to work on. The biggest thing to be careful of is the start switch assembly. Just remove the pulley and then carefully remove the end bells. Under one end bell, usually the rear, is the start switch assembly. They are mounted and attached in various ways, but all are made to be removed for service. Just gently disassemble keeping track of parts and the way it was assembled. Pictures are a big help here. When you get it opened up you can feel the bearings and look for other issues. Pay close attention to the end bells. It is common for bearings to spin in the bell and wear on the outer seating surface. The bearings are a slip fit into the end bells and a press fit to the shaft. This is a basic starting point for basic repair....Robin
Happily working on my second millionGave up on the first
Boyles Future Technology in Auburn, CA rebuild just about any motor on the planet. It is a hole in the wall, crap everywhere kinda shop. Their number is 530-888-6290. I'm not affiliated or related to them, just a satisfied customer. They are a little bit of a drive for ya but...
Keith
YES! Replace them yourself. Not hard, the motors, if older, are made to be taken apart and fixed, so everything comes apart in a reasonable way, even though you may need to be careful, and look out for wires and fragile insulators.
Often, the end bell and switch will come off with little trouble, the rotor has a setup to push and open the start switch, and the two are not interconnected. Some are more complicated to get apart, so look first and use force only after careful looking..
You will probably want a suitable sized gear puller for the bearings.CNC machines only go through the motions
- Likes 1
Sometimes it pays to have an experienced set of eyes look at something like this. I recently had a starter motor rebuilt. He said it was done and started listing parts replaced......fields?
Yup, when I got there he showed it to me and it was something I may have missed. It was worth it to me to have him do the work......correctly.
As a native Renoite, the motor shop that most people think of is, Brown & Milbery
http://www.brownmilbery.com
They are on Gentry Lane off of South Virginia st..
But as others have mentioned price to repair vs purchasing new vs doing bearing yourself.
Originally posted by blwn31 View PostBoyles Future Technology in Auburn, CA rebuild just about any motor on the planet. It is a hole in the wall, crap everywhere kinda shop. Their number is 530-888-6290. I'm not affiliated or related to them, just a satisfied customer. They are a little bit of a drive for ya but...
Keith
Originally posted by FrugalguidoAs a native Renoite, the motor shop that most people think of is, Brown & Milbery
As to doing it myself, I am reluctant since this is a 70-year old motor and I'm concerned that if I opened it up the connecting wires/insulation would crumble, or something. OTOH, as J Tiers points out, older motors are made to be repaired. I would feel better if I had dissected a few otherwise dead ones for practice.
