I'm cleaning up the shop today and needed a short break.
One of the things I've got sitting by but not yet in the scrap metal bucket is a roughly 8 lb cast iron Record anvil. You know, the cheap ones that are just cast iron and dent and burr up easily from small things being struck on them?
So I was just about to put the anvil into the scrap metal bucket and started to wonder... I've had a lot of luck with using the Loctite 680 on things. But they were always round shafts into round sockets which are nigh on perfect for these sort of adhesives. But what about the idea of bonding on a 3/8 to 1/2" (10 to 12mm) layer of harder "proper anvil hard" steel to the face? The face in question is 3x5 inches (80x125mm).
And I suppose the next question is what sort of pre-hardened steel would you suggest?
Or should I simply dress it up as best I can and gift it on to someone?
The blue thing's function has been taken over by the 7x10 x 1" slab of mystery steel which whatever it is it's a lot tougher than mild steel by a good amount. So much so that some spots were work hardened and I finally gave up trying to dress the face and got it surface ground at a local shop.
