I can deal with a drive screw, but this end cap is not coming loose. This is a cast iron sewer pipe in this 50's era house. It has a cast iron piece leaded into the larger opening in the pipe, and a close look reveals that the cap is brass- this piece being about 4 inches in diameter. I'm distorting it by putting pressure on the wrench, so it doesn't appear that I'll be able to unscrew it. I sprayed penetrating oil on it yesterday, and I hammered all around it today to help break the threads loose. I got the wrench on it and used my floor jack to put the pressure on- and I left it under pressure for awhile. Hammered all around it again with the wrench tight, but it doesn't budge.
What's my next step?
