I've seen people use a meat grinder for this but I don't have one. Cutting up silicone is a PIA using a blade. Anyone have a better idea to chop it up fairly small?
OT- chopping up & recycling silicone mold?
slap chop.(would probably work though....)
I just use scissors. Depending on your new mold shape It doesn't have to be in tiny pieces. I like using bigger chucks in the corners so that only fresh liquid silicone is touching the model. With the granulated meat grinder method you don't really have control over that. TBH I don't know whether it even matters or not though.
Originally posted by darryl View PostPresumably to use as filler in new molds?
JL..................
Originally posted by JoeLee View PostI have to question that too. How do you really recycle it?? maybe repurpose is a better word? You can't melt it down and use it over again. Unless there is an industrial method of doing so. Like paper, steel plastic etc.
JL..................Helder Ferreira
Setubal, Portugal
👍 2
Originally posted by Dan Dubeau View PostCured silicone will bond to new silicone, as long as it's clean and oil/release free. It's pretty common practice to recycle old molds by chopping/chunking them up and using them as filler in new molds. Silicone is expensive, and using old stuff can really lower you cost per part.
Originally posted by dian View Posthave you tried it? poured some resin on a cured object and tried to separate them?Last edited by Dan Dubeau; 01-24-2021, 07:11 PM.
👍 1
Near as I can tell it's a full chemical bond. I've even had success using cured household silicone caulk as filler. It's a bit stiffer than molding silicone, so it plays with the durometer of your mold, but it was a successful experiment (surprisingly). I'm designing some stuff to be cast right now, and when I go to make the molds I will most likely use caulk strips for filler around the outside to see if I can get a stiffer outer shell, with a more pliable inner. Mostly because at the moment I don't have any old molds to retire, and second, because I like experimenting. A tube of caulk is $5 vs about the same volume of molding silicone @$40 up here. I played around a lot with trying to use caulk for molding, but it turned out more trouble than it was worth.
I'm not sure you could use anything else as filler, but maybe? If it was fully encapsulated it might work, but it probably wouldn't bond to the silicone.
I've still got a couple more ideas to prove out to reduce my mold cost, but only so much time to play around.
👍 1
