Anyone recognize this 3 roll bender?
Don't think homemade. The sliding upper roller brackets appear to be cast, of cast iron or cast steel.
Rollers are exactly 2" and 3" with 3/8-16NC, grade 8 fasteners... maybe it isn't asian.
The driven roller is knurled.
Haven't found anything close surfing the web.Last edited by cijuanni; 01-22-2021, 08:26 PM.
Looks like it is to make sheet steel into a curved form, or straighten curved or rolled raw materials before cutting etc. . Maybe designed for a specific size of sheet material. Here is a photo of a larger one but the concept is the same. Tightening the adjusters gives a tighter curve etc.
S E Michigan
Originally posted by OaklandGB View PostLooks like it is to make sheet steel into a curved form, or straighten curved or rolled raw materials before cutting etc. . Maybe designed for a specific size of sheet material. Here is a photo of a larger one but the concept is the same. Tightening the adjusters gives a tighter curve etc.
Didn't think of that it might have been for straightening coil stock, which might explain the width, and why they way it is currently set up you can't roll a complete circle.....cuz they didn't need to.
That scrapyard gets a fair amount of coil stock, so that is a good possibility.
Originally posted by eKretz View PostWhy can't you roll a full circle? Should be able to just fine, that's a pyramidal roller.
The machines set up for have a quick release/hydraulic/slotted bearing support that pivots off to allow sliding the circle off.
👍 1
Originally posted by eKretz View PostYou can still do a full circle as long as ......
I suspect everyone here knows that steel is elastic and has an elastic limit, but thanks for participating.Last edited by cijuanni; 01-23-2021, 04:43 PM.
Originally posted by 754 View PostYou can roll a circle , I'd you can remove it.
but good luck welding said circle , grinding it, then trying to 're roll it round..
width.? Do you have a tape..?
With any of these types of machines, brakes, shears, rollers the capacity is given in the width and thickness of material (usually mild steel) that it can handle w/o breaking, deforming or poor results.
That is why I asked if anyone recognized it.
It wasn't to find parts.
It wasn't to discover Young's Modulus of Elasticity.
So back to the question.
