Originally posted by nickel-city-fab
View Post
I've had a number of times where small end mills used with my spindexer forced me to extend the piece out further than I wanted. To get around this to some extent I picked up a 3/8 size holder similar to THIS ONE . Paul, for your needs just to clear the nose of the spindle and let you see what is happening one of those might be just enough.
But it's still not all that great for small parts in the spindexer. The nose diameter still requires more stickout of the smaller items than I'd like. And I still can't reach in quite far enough if I were needing to put a slot through and out the bottom side of a small part. But the simple plain extension talked about earlier would be pretty much what I need to use with the smaller and shorter end mills.
I drew this up over my morning coffee and will make it a bit later today. It'll be done from 1" stock or some 3/4 hot rolled if it is big enough to finish to 0.750 after the scale is gone. It'll all be done in one holding so the OD and ID run true.
