10th of a foot measurement is used in oil field core measurement and land surveying
What did you screw up today?
In the above picture The bore was called out 5/8" for a steam engine bearing block. So in the middle of the boring process the grand son comes in the shop and asks " whatcha doing gpa?" So I explain and continue on with the boring process, making cuts and confirming the size. Made a few cuts and hit it right on the number, .652".
Damn
lg
no neat sig linenear Salem OR
- Likes 4
Originally posted by larry_g View PostSo I explain and continue on with the boring process, making cuts and confirming the size. Made a few cuts and hit it right on the number, .652".
Damn
lg
no neat sig line25 miles north of Buffalo NY, USA
- Likes 2
Typical "chip in the QCTP", 100 parts using 3 tools, face, OD turn, drill then bore.
The bore is .793" +.002 -.000, after 30+ parts one finished at .797".
If the bore or OD tolerance is less then .001" I do not change tools at all with a tool post, do the critical operations without removing the tool block if possible.Last edited by Bented; 05-20-2021, 07:08 PM.
- Likes 1
Originally posted by Bented View Post
If the bore or OD tolerance is less then .001" I do not change tools at all with a tool post, do the critical operations without removing the tool block if possible.25 miles north of Buffalo NY, USA
When is a tapered tap (R1/4) not a tapered tap? When it's bloody parallel all the way downBranded, etched R1/4, nice boxed set, no use. Luckily I worked out that it didn't match the tap drill size before I (tried to) tapped the hole! Bank holiday weekend here so a good week before the right tap will turn up - assuming I can find one that doesn't claim "UK Seller" or "UK stock" and then post them slow-boat from China
Don't get me wrong, I don't mind buying direct from China (with the silly token postage rates) - it's not like it's not come from there anyway - but when I don't mind waiting for it to arrive.
Also, my part is a rectangular cuboid so there are four long faces. I managed to drill two of the wrong faces because I'm a half-wit. Those I can plug though. I think the world is telling me to call time on machining today!
Originally posted by Bented View PostThe sound of a failing live center.
https://bented.smugmug.com/My-First-Gallery/i-LNWgQrG/A
what am I supposed to hear? Just sounded like normal machine noises to me
'It may not always be the best policy to do what is best technically, but those responsible for policy can never form a right judgement without knowledge of what is right technically' - 'Dutch' Kindelberger
- Likes 1
I mowed.
Last time I noticed the engine was smoking out of the fan hole when I shut it off. I opened the dipstick and it smoked out of there too. Oil was considerably lower and darker. Well I was gonna change the oil but got lazy so I mowed again today. I could definitely smell oil when mowing, but it was mowing fine. When I stopped I pulled the dipstick before shutting it off. It about parted my hair with the oil mist it blew out.
I suspect I blew up the ring lands by starting it with either every time. Damn briggs fuel pump won't pump without the motor running. So I guess I'll get to try my hand at boring the cylinder if it's screwed up.
Piece of junk.
????? Should be enough fuel in the carb reservoir to start up and get the pump running. I assume you have the old type carb on the fuel tank with the pull choke or the like?
I like the bowl type carbs, but all of them ought to start on what's in the reservoir. You may have a leak. The old carbs that are in/on the fuel tank have to be flat to a couple thou on both parts or they don't work right, but that is not involved with gas in the reservoir.... maybe a crack? or enough leakage to mess up suction until there is a lot of airflow.
Or maybe you have some totally other carb on a newer mower. Some new units are POS from the get-go.4357 2773 5150 9120 9135 8645 1007 1190 2133 9120 5942
"There's no pleasing these serpents"......Lewis Carroll
It's a John Deere L120 I think. All I know is that is has a vaccum fuel pump and it won't do diddle without it running. Dad replaced it once before, didn't help.
I'll admit, as a youth, carbs are before my time and I don't care to learn. Only so much knowledge once can obtain in this world and gas engines and carbs aren't high on my radar. I know a lot of old timers will clutch their 4 barrels til they die, but I'd just assume everything was diesel or electric. No love in my heart for ****ty little gas engines. So I don't tend to fix them if they "work".
Dad will probably help with the fuel side of things and I'll do the mechanicals and it will run again. Probably. If not I'll kick the POS to the curb and find a real mower.
Ah, well, I don't love them either, but I do fix them. It usually is not hard.
They are what they are, you deal with them on their terms, or not at all. Like most things.
I find that when things are fixed right, they keep working. Otherwise, less so.4357 2773 5150 9120 9135 8645 1007 1190 2133 9120 5942
