Wanted to share my project of the past few weeks. My JD came with an “Original Tractor Cab” brand soft cab which I used one winter and found quite mediocre so I never reinstalled. 2 years later I got around to designing and building my own. Reused to plastic top ans wiper motors only. Front and rear glass are safety glass and sides are all lexan. Only machining content is the door hinges. Let me know if there any questions on the build.
Semi OT: tractor cab build
I don’t see where the air conditioner for summer use is mounted.
A farmer I knew got a new tractor with an air conditioned cab. I commented to him that I always see farmers with a fancy pickup truck parked at the edge of the field while they sit in the heat and dust for 12-16 hours plowing and tilling. His reply was “ I have no idea why we did that! I have AC, cell phone and internet, stereo and GPS. Doesn’t seem much like work and I don’t even get dirty!”
- 1 like
Very nice JC. I have looked at a few cab builds on some of the tractor forums, and I must say that yours is an excellent job. Speaking of summer, couldn't you just remove the doors and still have a sunshade? Down here in the Ohio River valley, air conditioning is almost a necessity. Temps in the high nineties and humidity to match.
Sarge41
No rear wiper at this time but I can easily add one. And yes I designed and built it so the doors lift off. My lawn is flat and has some lower trees and so I would run the ROPS folded all summer, the the plan will be to remove the cab but it could always stay. The front and rear glass both come out easily as well. I estimate I can disassemble and install ROPS in under an hour by myself.
Looks good. When I was 13 or 14 I talked my Dad into getting a buzz box so I could make a cab for our Massey 35 w/ a snow blower. Angle iron, plywood and plexiglass. It didn't look as nice as yours, but with a long farm lane and on top of a large ridge where the wind just howled it was like a gift form the gods. The drifting was so bad we'd often have to blow the driveway several times a day. We'd get dense 6' high or more drifts at the road (where the banks from the grader were). Mine was held on by gravity, it straddled the back axle and the frame of the front end loader, Dad and I could lift it off. Thanks for the pic and the memory.in Toronto Ontario - where are you?
